JD #5 section question
Ol Snuffy
06-04-2002 08:50:14
On 6-3-02 there was a post by "Mark" that mentioned a special double section or triplate that goes on the outer end of the sickel bar on a JD #5 mower It is intended to keep the end from plugging up. Does anyone have a JD part # for this special section? I have fought this problem of the outer end pluging up right under the grass board bracket and am hopeful that this special section will cure the problem. Thanks
Mark
06-04-2002 10:11:20
 Re: JD #5 section question in reply to Ol Snuffy, 06-04-2002 08:50:14
Ol' Snuffy,
I bought the double section at my local farm store, the same place where I buy guards, etc. The large triangle seems to be a little smaller than a normal section and the one on the end is quite a bit smaller. I just found one that had the same hole pattern as my regular sections and put it on the end of the bar. If you need a part number, I can probably dig it up. It sure helped my problem.
Good luck,
Mark
Don
10-19-2003 10:16:40
 Re: Re: JD #5 section question in reply to Mark, 06-04-2002 10:11:20
Thanks, Mark. That's the info I came to this site for. I've seen those special cutters at TSC and Rural King Websites at around $8 for a 2-pack. I held off because I wondered about that third hole, but I guess you don't have to use it.
