JD 24T Baler
MIke
05-29-2002 22:14:43
Anyone know or know where I could find the physical info for a JD 24T baler. Believe I found one and it would have to be hauled home. Was wandering, if I got it, what would I need to get it home. Got plenty of truck (Ford F-250 Super Duty Diesel) but how big of a trailer would I need. I have a 18' pipe top but unsure if it would fit. Any thoughts?
Thanks in advance.
Doug in Il.
05-30-2002 05:43:21
 Re: JD 24T Baler in reply to MIke, 05-29-2002 22:14:43
I hauled one recently. They will fit on an 8 foot wide trailer with no problem. Your 18 footer will be long enough too! Weight is about 2500 lbs. for a pto machine. An engine drive will be about 300 lbs. more.
Cole in Mo.
05-29-2002 23:57:49
Hi Mike, if the balers not that far away I would pull it home, if the tires are good, check the wheel bearings, make sure its in the pull down the road position, and go. you got plenty truck, I pulled one 80 miles on major hiway with a 1985 ford ranger 2 wheel no problem, stayed between 45-50.
