Vac-14 Disk ?????
HOUTZ
05-28-2002 19:36:41
I want to thank all for past help with my tractor and now ask this. We have a 6000 sq.ft garden.No big deal.I used to rent a rototiller till I got tired of getting the living SH-t beat out of me.I now use a 2 bottom case plow attached to our vac-14.It works wonderfully.I'am now in the market for a disc, disk,harrow,whatever.Please,if You know,will You give some recommendations???Thanks.You guy's are the most !!!
Dave in Mo
05-30-2002 04:56:28
 Re: Vac-14 Disk ????? in reply to HOUTZ, 05-28-2002 19:36:41
Your VAC is about 15 HP on the drawbar, so if you pulled a 2 bottom with it, that's darn good! You now need a disc to chop up the ploughed ground. I can pull a 6 1/2 footer with our Case and that's all she can handle. So go to a Farm and Home store and buy a smaller 2 row disc for about 350-400 bucks. You may be able to pick up a used one, but they usually need bearing and such.
Dave in Mo
05-30-2002 04:53:27
TB
05-29-2002 15:10:42
Being that you have both typs of hitches draw bar and the eagle hitch I would say whatever you could find that is in good shape at a fair price about 8' wide should work nicely. Good luck.
chuck
05-29-2002 13:24:32
answer the man's question. i can't because i don't know anything about a case VAC-14.
Slamfire
05-28-2002 20:51:25
The various harrows all have strong and weak points. You'd get the most bang for your buck with one of the chain harrows.
Slamfire
05-28-2002 20:50:49
Ken
05-28-2002 19:46:02
Use the tiller correctly and it won't beat the SH-t out of you
Houtz
05-28-2002 19:50:07
 Re: Re: Vac-14 Disk ????? in reply to Ken, 05-28-2002 19:46:02
Get a life.
