Implement hp
buckman1956
05-28-2002 02:01:40
i've got a jd 3020 diesel .what size implements can i run with this ? ie: drawbar disc , cutter mower , bottom plow & square baler . thanks
paul
05-28-2002 06:01:01
 Re: implement hp in reply to buckman1956, 05-28-2002 02:01:40
Tillage depends so much on your soil type, and how deep/hard you work the ground. I'd put a 3 bottom plow & 12' disk on it, but might be different where you live.
Any of the older balers should work fine, I think you could pull a 9' moco, any sickle bar, a discbine might be a little much for it?
