LOts more info and a description The plow is 10� 6� from the tail wheel to the hitch. It is 5�4� from outside hub to outside hub. It appears to be a 1 bottom. The reason I�m not sure is something is missing . there is a 2X3� piece of steel which bolts to the main beam and has two bolt holes. the other end is 16� from the main beam. (its hard to describe). Maybe for a rolling coulter. The main beam has PO23403 stamped on it. The hub of the mechanism that allows the wheel to drop into the furrow has PO1618 with IH inside a circle stamped on it. right side The back plate of that hub has PO1415 stamped on it with IH inside a circle . The trip lever that controls the drop wheel and allows for wheel lock and free wheel has a casting at the fulcrom point with has PO1422 and the IH circle above the numbers. The rocker arm that actually locks inside the hub has the word CANADA stamped on it. The hub on the free operating wheel has IH in circle and PO1258. left side. The plow has two adjustment arms. the right adjustment has 15 adjustment slots. the left one has 11 slots. With the plow was a coulter with RO2561 stamped on the casting. The hub of the coulter has SA1346 on it. There was no casting to connect the coulter assembly to the plow. The drop wheel mechanism appears to work but it is very stiff. I�ll go pester the old IH dealer in town this week to see what information he still has. Then off to bother the Case dealer to see what he has.
