Override clutch
azjbird
05-25-2002 07:19:42
I finaly found a good used bush hog, 5ft. ford for my INT. #2424 It`s kind of cosmeticly challanged (what the heck, so am I) but mechanicly sound and all there. I tried it out and it works just fine. took it slow and easy in 1st and 2nd gear. My INT. has a 2 stage clutch and it seems to work just fine. It does take a long time for the mower to spool down though. Do I need an override cluth for saftey? I did not feel that the mower was pushing me around while working. I stopped and started a few times to see how it would act. The mower needs some tlc and is now up on blocks for now. If I need to install the clutch now would be the time. Thanks in advance to all, J.
D. Mosey
05-25-2002 14:27:10
 Re: override clutch in reply to azjbird, 05-25-2002 07:19:42
You'll need one if'n yer mowin in tall & thick brush. It'll save on the mowers gearbox & shear pin. Gives you enough time to raise up when it bogs down. We got one on our 6' bushog an it has saved our'n.
thurlow
05-25-2002 19:37:40
 Re: Re: override clutch in reply to D. Mosey, 05-25-2002 14:27:10
D.; you talking over-ride (over-running)clutch or slip-clutch??
D.M.
05-25-2002 19:45:30
 Re: Re: Re: override clutch in reply to thurlow, 05-25-2002 19:37:40
Yep, slip clutch... thats what I was meanin to say... hope I didn't cause no confusion.
paul
05-25-2002 07:28:41
If your tractor has live pto, you don't need the orc - already built into your tractor.
--->Paul
