Just a test......
Jim.UT
05-23-2002 08:30:01
....to see if it's possible to post something on this board without posting it 2 or 3 times. What's up with all the double posts on this board?
Ken Crisman
05-24-2002 19:23:07
 Re: Just a test...... in reply to Jim.UT, 05-23-2002 08:30:01
Well we can look at this way : twice the advertising for the same price .I was impatient too, as you see . Ken
allisguy
05-23-2002 18:01:36
In my case I'm kind of computer illiterate so a double message is just the result of my incompitence.
Well, OK, there does seem to be a problem.......Jim.UT
05-23-2002 08:33:31
When I hit the "Post Message" button, it chewed on it a long time without appearing to progress. I think the cause of the double posts is some of us are too impatient and when it doesn't happen right away, we hit the button again. Instead of doing that, just use your back button to go back to the discussion board, then hit your refresh or reload button. Your post will be there.
Mosey
05-23-2002 13:59:04
 Re: Re: Just a test...... in reply to Well, OK, there does seem to be a problem.......Jim.UT, 05-23-2002 08:33:31
"I think the cause of the double posts is some of us are too impatient and when it doesn't happen right away, we hit the button again. Instead of doing that, just use your back button to go back to the discussion board, then hit your refresh or reload button."
That's not the problem. I don't hit the Submit button more than once. I hit it once, and it hangs. I back out and go back to the post and it's there at least twice.
Mosey
05-23-2002 13:59:40
 Re: Re: Re: Just a test...... in reply to Mosey, 05-23-2002 13:59:04
Well, except this time!
paul
05-23-2002 10:43:09
That's exactly what I have to do about 50% of the time I post a message - back out of it & reload. Reading messages come up fairly quickly, but posting a message - I think once it gets in it's waiting loop I could be waiting for an hour or more - have taken many bathroom breaks & it's not back up when I'm back up.....
I mentioned it to Kim a while ago, but sounds like I'm the exception to the rule? I was thinking too that it's the reason for so very many double postings at times.
--->Paul
Impatient, impatient
05-23-2002 08:54:11
What, What, you you think think we we are are impatient? impatient? Bulldung! Bulldung!
05-23-2002 08:53:55
05-23-2002 08:53:46
Dave_D
06-03-2002 14:26:27
 Re: Re: Re: Just a test...... in reply to Impatient, impatient, 05-23-2002 08:53:46
I had an ISP with the same problem. Turns out to be the mail server (smtp) was overloaded.
This is a great site, this is such a minor problem, nothing to get upset over.
-Dave
