Plow Questions
Bill Grumbine
05-21-2002 10:57:27
Good afternoon all
I have a '63 Fordson Super Dexta (39 HP diesel), and am thinking about how I can use it in the garden to break up the soil. I have a walk behind rototiller, but it is really beating me up trying to break up the ground, which was planted in soybeans last year.
My questions come from looking through the Tractor Supply Catalog. I see one bottom plows, two bottom plows, middle busters and sub soilers. Would anyone care to inform me as to the differences and advantages of one over another? I am thinking that if I can turn the soil with the plow, the rototiller will have a much easier time of it.
Thanks.
Bill
Bill Grumbine
05-22-2002 18:53:01
 Re: Plow Questions in reply to Bill Grumbine, 05-21-2002 10:57:27
Thanks guys, for the informative answers. I am not that good with the plow, and it will probably take me some time to get that way. I did get the garden plowed up, and it did look pretty good, for a beginner. It took me less than half an hour and it was done.
Today I got out and rototilled the whole thing to a very even consistency, and even that only took me a bit over an hour. The garden is roughly 2400 sq ft - big for some, small for others. I plan on having big paths between the rows so I can rototill to keep some of the weeds down.
I have having a lot of fun with this tractor and all the things I can do with it, and this site is very valuable for learning a bit of how to do it. Thanks again to the three of you for your responses.
Bill
TomH
05-22-2002 17:44:03
If you are really good with the plow, the ground will be fairly level without big ridges and furrows, but I'm guessing you're not there yet ;^)
Another alternative is to get a disk. It doesn't work as deep as a plow, but it will probably be easier to follow it with the rototiller.
bcPA
05-21-2002 23:15:41
a used 3 point should be the way to go. I would stay away from a plow that requires cast iron plow shares. We did have a used massey ferg. 3 bottom trailer plow that we pulled with a int. M. That was the best plow set up we ever had. think before you spend your money. Get some one who knows more than you to go with you when you go shopping. Good Luck
F14
05-21-2002 16:43:05
A middlebuster cuts a furrow and throws dirt both ways from the center, and is often used to build "hills" or raised rows in already worked ground. Never tried it, but I don't think it would work too good on "virgin" ground.
A subsoiler is a shanked implement used to dig much deeper than a plow and break up "hard pan" or compacted soil generated by years of tractors driving over it.
A two-bottom plow (as you have already discovered judging by your post on the tractor page) is just the ticket for what you want. It cuts a furrow several inches wide (10, 12, 14 and 16" bottoms are common) and turns the dirt completely over, burying residue and breaking up the soil. Trick is to catch the soil at the right moisture content. Too dry and it plows hard and turns to dust, too wet and it turns to cement when it dries.
And BTW, I wouldn't give you a nickel for any plow sold by TSC. Too lightly and cheaply made. Very few farmers plow anymore, minimum till is both more ecologically sound and cheaper, so used plows are available pretty inexpensively. Get someone that knows plows to look it over, as wear parts like points, shins and moldboards can be hard to find for older plows.
