Sickle mower doesn't cut good
Mosey
05-20-2002 06:51:33
I recently bought a Ford 515 sickle mower. I gave it a complete lube job and used it for the first time a couple days ago. Everything works good, except it doesn�t cut as well as I had hoped. I�m using it to cut grass that�s about 2� tall at the edge of a ditch bank and under trees.
After it cuts the grass, the grass just lays on top of the cutter bar. So, I have to back up to get the grass off. I�ve tried angling the bar so the guards point up, but that didn�t help. I took a closer look and some of the grass is getting stuck in the guards in front of the knife sections. It also doesn�t cut real good even if there is no grass laying on it. Most of the knife sections are not down tight against the ledger plates on the guards. Can the guards get bent down? Or, can the knife sections get bent up? Can I bend them back with a hammer or will they break if I pound on them?
The manual suggests using �cut-free guards�, has anyone ever used these? Will it cost a fortune to replace all of the guards and knife sections? Thanks.
Mosey
05-21-2002 05:50:56
 Re: sickle mower doesn't cut good in reply to Mosey, 05-20-2002 06:51:33
Thanks for the ideas. I did say the grass was 2 feet (2' not 2"). Anyway, I'll check the angle of the bar and the hold down clips and try going faster!
Mosey
05-21-2002 05:47:56
TomH
05-20-2002 16:49:49
You're probably going too slow. A sickle usually cuts best with more ground speed than less.
Touch up the knife sections with a grinder. They should be sharp enough to cut you.
Make sure the cutter bar has a little bit of "lead", it should angle forward when you are not moving so it gets pushed back to perpendicular under a load.
Ralph Butteris
05-20-2002 07:41:18
Have you checked the sickle cutter bar hold down plates. They designed to hold the cutter bar knifes down close to the bottom of the guard that acts as the second half of the sissors cut.
Mosey
05-20-2002 07:50:49
 Re: Re: sickle mower doesn't cut good in reply to Ralph Butteris, 05-20-2002 07:41:18
I just noticed where I missed something in the manual the first time through. It says to �align the guards by striking the forward end up or down with a hammer�. It also says the knife clips can be adjusted by �striking the forward end of the clip up or down�. So, I guess I�ll get my hammer out and start wacking!
paul
05-20-2002 09:27:19
 Re: Re: Re: sickle mower doesn't cut good in reply to Mosey, 05-20-2002 07:50:49
Difficult to whack _all_ the guards up - try getting the clips down first. :)
Also, check the registration of your sickle - that the knifes are going from the center of one guard to the center of another guard during one rotation.
Sickle mowers have tough going in short young fine grass, or if there is dew on the grass. There is also a 'best speed' to travel, depending on coarseness of stems, wind, phase of the moon - try slower & sometimes faster, see if that works better.
--->Paul
Mosey
05-20-2002 07:47:22
The hold down plates are all there. Is there an adjustment?
Mosey
05-20-2002 07:44:21
Bill
05-20-2002 20:27:32
 Re: Re: Re: sickle mower doesn't cut good in reply to Mosey, 05-20-2002 07:44:21
I never tried cutting anything 2in tall, What do you expect the mower to do cut it down to 1in. I never cut anything generally less thanm a foot tall. By then, it had soe use as hay, it had a stiff stim to cut thru, and less likelihood of bending to easy before being cut. But as to cutting with a dew on. On of the best cuts I got was when I was cutting and about through, and it was pararie hay, and a while of a storm came up. I had a MH horse mower, and I stopped and asked my neighbor on the mower what he wanted to do, and he said he didnt care, and we had like only 3 more passes, and we were already drowned, so I went ahead and cut it with my 1934 case CC. It cut better the any of the rest
Davidj
05-21-2002 04:30:51
 Re: Re: Re: Re: sickle mower doesn't cut good in reply to Bill, 05-20-2002 20:27:32
Uhhh... I thought he said 2' not 2".....
