Ford Baler
Brian
05-15-2002 12:11:16
Can anyone give me advice on a Ford Baler? There is one for sale in area fairly cheap.
REDNECKMATT
05-17-2002 18:53:14
 Re: Ford Baler in reply to Brian, 05-15-2002 12:11:16
I have a Ford 250 baler (a red one) I payed $100 for it missed abought the first 10 bales when I brought it home I changed the twine and it may have missed 5 ever since then. I also have a Ferguson 3point rake and love it only bad part you are limited to a tractor with 3 point and using the truck to transport is out of the question.
Brian
05-16-2002 05:02:45
Thanks guys for the input. I don't know anything about it other than what's in a local newspaper. The ad just says ford baler and rake $500 or best offer. And before I went and looked at it, I wanted to know if I would be wasting my time before I made the hour trip.
jflaharty
05-17-2002 16:43:34
 Re: Re: Ford Baler in reply to Brian, 05-16-2002 05:02:45
I have a 3pt PTO hitch Ford rake and I think it does a fine job. I also have a 530 baler that took me awhile to get set up but I did, with the help of Jerry, it is the first baler I have owned and I think after 1 1/2 years, I know it, particularly the knotters well. it ties a good knot but as earlier posts suggest, make sure they appear greased up and taken care of. These balers can look pretty rough on the outside but if the internals are cared for they will bale with the other colored balers. They will often use up less hp because the plunger is outfitted with rollers unlike the JD14t or 24t that slides on wear plates. This allows me to bale with a small wagon hooked on back with a 9N Ford tractor. Some people claim that can not be done, it can be. Your local NH dealer can provide you with the important parts although, like anything else from them, they are not cheap. I would also be sure to have the baler run for you before you buy. At that price, it should be operational. The rake seems a little high priced at 500 but if it is in good shape it is not out of line, watch it run too. Good luck
paul
05-16-2002 12:24:54
Locally they pretty much don't sell, but for scrap iron prices. So don't seem too eager, & offer a lower price.
Locally NH & JD balers are what work, & what you can find parts for. The other machines just get no respect, and have no support.
Since I have only ever used one baler, and it has been on this farm longer than me (and maybe works better too???) I'm kinda partial to NH. :) But it soulds like JD & NH figured out how to make knotters that work, while the other companies were kinda hit & miss on it. You might get a good Blue one that works, and you might not.
Be interested in hearing more about setting some timing off 180 degrees on them, what part exactly? Obviously not the actual timing of it, that breaks needles... ;)
--->Paul
Jerry D in NC
05-16-2002 20:44:16
 Re: Re: Re: Ford Baler in reply to paul, 05-16-2002 12:24:54
NH makes some fine balers as does JD. I will not deny that but the Ford 53X and 54X were some good balers that were economical and well received. They would bale well with smaller HP tractors and fit a smaller farm which was the target market. Ford was just starting the larger tractor series when they bought NH and with that brand they did the smart thing in dropping their line and investing in enhancing the NH baler that was on the market. I have not had any parts that are not available and comparably priced to NH and JD. The dealer network was the key to support in the area and in parts of the country Ford balers were the dominant brand. Western NC where I grew up the Ford square baler is still the majority of balers in the field. Again the dealer network was Ford based. NH's and JD's were too expensive. Today more people know how too work on these brands so they are the largest market share. The knotters in a Ford baler are so close to the NH and JD's that setting them up is the same procedure. I have worked on all three and find little difference between the three.
Here in central NC the Ford baler got a bad name because a simple error in the manual for setting up the feed forks causes them to not feed hay correctly into the chamber. It seems that the dealers set them up by the book and these balers will not feed hay into the chamber very fast at all. If you read the manual and look at the pictures you will see all of the Fords have the two forks feeding 180 degrees apart and they will eat a big windrow as fast as you want it. Down here any farmer will tell you that a Ford baler will not get the field baled in a day and with those forks set up according to the manual it is true. This design of feed forks works better than an auger and they do not wear down like the aluminum forks on a NH. It was a great feed system that was simple and very low maintenance. Set them up the right way and they surprise the biggest doubters. Anyone that has baled much knows that to have well shaped bales you have to have baling speed and windrow consistency right or they will be banana shaped or light on top with varying lengths. That was what happened here in central NC when they were set up wrong. I have not seen one in this part of the country that was set up correctly and I imagine that it was that way several places. Mine has not missed a knot in three years and that amounts to several bales of hay.
I contend that a Ford 530 baler for $500 is as good a baler as any other baler made in 1965 and is just as well supported in parts as the others. Like anything else how it was cared for means alot and how well the operator knows to use it will make the difference. The biggest difference is that at the prices a Ford baler bring you can afford to buy at least one for parts.
As for the rake, I know several people that have a 503 PTO driven 3pt rake. Most of them would love to have another for under $500. I don't personally have the experience with that rake because I have the NH 55 but I am sure that Jim UT would comment on that issue.
My point is that I have equipment from many brands, my MoCo is a JD, my rake is a NH, my baler and tractor are Fords. All work great and have been inexpensive in cost yet sweat has flowed on a couple of them. Don't say no because it is not todays market leader or the paint is not your favorite.
Paul, this was not written to you because I know you love your Ford tractors and you do give great practical advice from experience. I thank you for the help you have given me in the past. I would encourage you to pick up a couple of those scrap metal priced Fords to back up that NH that must be older than the hills if it was there before you. LOL
paul
05-16-2002 21:38:53
 Re: Re: Re: Re: Ford Baler in reply to Jerry D in NC, 05-16-2002 20:44:16
Internet communications & advise as it was meant to be. :)
'Here' in my part of southern Minnesota, I have seen 4 blue balers in several decades. One has been at the Ford dealer's lot for over 5 years. One is parked at a small hobby farm. Two were at auctions, and I don't remember, but went cheap.
Also, I have seen less than 10 pto siderakes... They also just are not at all popular around here. I have never seen one actually working.
For my location, having a blue baler would actually be difficult! :) Didn't know they ever actually sold any in volume anyplace! :)
I didn't say anything about the siderake, because that whole pto idea never caught on around here. I wouldn't get one because they must not work here - no one used them ever. But they might be the best ever in other hay conditions.
$500 for both the rake & baler probably isn't bad. As long as the ad is 'or best offer' I'd offer something. ;) In my location, $1000 for the pair would be way too much. But maybe not in other locations....
Enjoy the conversation, Jerry. That's what it's all about, getting out of my little corner of the world and getting a better view of the big picture. :)
My 270 baler must be close to 50 years old. Think dad got it when it was 4? We run 3-5 thousand bales a year through it. Never sounded like much, until I did the math a couple years ago..... Wow. Lotta bales. Hope it does a few more, I just got a bale basket for it this year. Cheaper than trading in for a bale thrower & racks....
--->Paul
Jerry D in NC
05-17-2002 10:12:22
 Re: Re: Re: Re: Re: Ford Baler in reply to paul, 05-16-2002 21:38:53
Well you are certainly correct about getting another perspective on farming with all of the diversity here. I love this board for getting real information. You and Tim(NJ) told me about the JD 1207 before I bought it and your setup advice helped a bunch. It just got through mowing orchard grass thick enough to bale ~ 100 bales to the acre and 10 acres of alfalfa better than we have been able to get it to cut with a discbine. Those 3pt rakes work good in small fields where getting in the corners and around trees, rocks and fences. That is the unfortunate way we easterners and hillbilly's have to do. I have seen those fields of yours in the background of the rake pics you sent. Oh to be able to set a plow in a field you could not see the end of. LOL Again, thanks for the imformative dialog and hopefully we have helped Brian with his question. Don't be scared of a Ford baler unless it is the only one in the state. LOL
Jerry D in NC
05-16-2002 05:20:26
Call the seller and see what model it is. If they don't know then see if they know what color it is. If it is blue then you are definitely interested, if it is red then you may be interested and if they can't tell which color then don't waste your time because rust is not a good color for a baler of any brand. $500 for the baler and rake is a great deal if either are in usable condition. Also see what kind of rake it is and again if they don't know then ask colors. Not as good an indicator as the baler but is a start.
BTW If you are looking for a baler and rake I would be planning the trip. At that price it will probably be worth going to look at it if nothing else. How familiar are you with hay equipment?
Jerry D in NC
05-16-2002 05:15:24
Brian
05-16-2002 09:13:33
 Re: Re: Re: Ford Baler in reply to Jerry D in NC, 05-16-2002 05:15:24
I believe the rake is also Ford. I am not too familiar with hay equipment on an expert level. I've helped others work on them and I am also pretty mechanically inclined. I am just starting to get into this small scale farming stuff so any advice is well received.
john2510-3020
05-15-2002 19:53:08
Jerry is right on almost everything i have seen him talk about on ford balers.WE had this discussion last summer. We have a ford baler and it ahs baled 6000 bales a year and is getting ready to bale some more this summer. Ours was bought new in 69 or 70 and has never missed a beat until about 3 or 4 years ago when we had to replace the knotters. They dont bring as much because people dont like them but it would make our tractors get down and work in heavy windrows. We had a 7000 ford and it would grunt sometimes. We set it at about 60# bales and they seemed to be pretty dence. Jerry has sasid that to get it to eat hay (and this is true as mine is set this way) is to set the fingers 180 degrees out of tune. I think you should get the ford you shouldnt be disappointed. John
Jerry D in NC
05-15-2002 18:13:00
Jim is way too kind and if I am the most knowledgable on these balers we are in the dark. LOL
Need a little more info on what model and such but I will tell you I have followed a Ford baler for many a mile in my youth and baled many a bale here of late with one. We got a couple of folks on here that can help. Best thing I can offer on the info you have given is Ford balers would bale great even if the color blind majority here don't think so. That just makes them cheaper.... LOL
Jim.UT
05-15-2002 14:08:24
The guy that seems to know the most about Ford balers uses the handle "Jerry D in NC". You might surf this board and the Ford board looking for a post by him, then send him an email. Or just wait and he'll probably weigh in with a comment in awhile.
