what do you think chisle (plow)???
plowen
05-09-2002 19:50:21
I have an old case 3-16 that pulls hard must be sprung.Im thinking of cutting off the bottems and mounting 4" twist chesle shovles on it any ideas or suggestions or comments app.
jal-SD
05-10-2002 07:17:43
 Re: what do you think chisle (plow)??? in reply to plowen, 05-09-2002 19:50:21
IMHO, Case plows do pull a little harder than other brands, probably because they do a better job. We had IH, JD & Case plows when I was a kid. Case pulled harder, but would bury any & all trash w/o leaving anything showing. Plowed under some sunflowers & fireweeds once that were taller than radiator on the H. Had to put #9 wires on the IH & JD plows to help bend the flower's heads down & get plows to cover 'em. Case plow covered 'em w/o wires or problems. BTW, does it scour good? If not, its out of adjustment & that'll make it pull a LOT harder. Plows should scour up in a couple of hundred yards or so, if the mulboards aren't really rusty. If they don't, get the book out & read the section on adjusting the plow. When I worked for a dealership one summer, we'd get them set wrong from the factory. (My $0.02 worth. jal-SD)
jal-SD
05-10-2002 07:17:04
JMS/MN
05-09-2002 23:05:12
If the plow is sprung it would be apparent by looking at it- the bottoms would not line up when sighting across them, etc. If you took them off and mounted chisel shanks on them, you would be tilling every 16 inches, which is too far apart to do a decent job. Most chisel plows run on about a 12 inch spacing. i.e. a 12 foot chisel has three ranks of chisels, for a total of 12 shanks.
