Hay Wagon
TwinCreek
05-07-2002 10:53:57
I've begun building a 5th wheel 6' x 12' hay wagon. I'm using some old mobile home axles. I want to use a brake drum and spindle from one of the axles as the axle pivot. Has anyone ever done it? Will it be strong enough? Thanks.
paul
05-09-2002 14:38:24
 Re: Hay Wagon in reply to TwinCreek, 05-07-2002 10:53:57
The folks over at 'tools' section seem to know a lot about trailer building.
To me 12 x 6 seems small for hay, and real small for a 5th wheel....
It'll depend on the rated load & age of the hub I'm sure, older were often stronger. Mobile Home axles are not built very strong.
--->Paul
mark
05-12-2002 19:47:13
 Re: Re: Hay Wagon in reply to paul, 05-09-2002 14:38:24
Mobile Home axles should be allright for you are not going to get a hole lot of hay on a 6x12 trailer.Unless you are going to put round bales on it .Now that a hole diffrent story.
