Killing a field with round-up????
Mark
05-05-2002 15:43:27
I am planning on killing the grass/weeds in a field and I was wondering if any of you could tell me how much Round-up and water do I need to mix to kill off one acre. I dont know what kind of grass it is.
Thanks Mark
Wayne
05-07-2002 00:55:54
 Re: Killing a field with round-up???? in reply to Mark, 05-05-2002 15:43:27
10 gallons of water an acre is good enough tough perenial [sp] weeds will require up to a gallon o round up an acre.
Wayne
05-07-2002 00:55:44
Dan
05-06-2002 19:27:02
I mix some 2 4 D with roundup to kill the broadleaves. roundup will kill them but takes longer. 2-4-D is almost instant gratification, broadleaves die in a day or 2. You can still buy 2-4-D in gallon containers without a pesticide license at least here. Roundup ultra has a surfactant in it already but if the roundup you get doesn't, use some surfactant or "booster" with it to make it stick better.
Andy in Ga.
05-06-2002 15:02:49
I use about a quart per acre and put down 25-30 gallons of water per acre. That will kill most weeds.Now down here in Ga. ,we have bermuda grass,takes about 6 quarts per acre to do her in. Andy
JMS/MN
05-05-2002 20:03:48
Calibrate your sprayer to determine how many gallons of water you spray per acre. Then use about one quart of Roundup per acre.
charlie
05-05-2002 16:11:28
i mix 1 pint in 50 gallons of water per acre.
paul
05-06-2002 08:46:17
 Re: Re: Killing a field with round-up???? in reply to charlie, 05-05-2002 16:11:28
I believe you are using a lot more water than is recommended. I think 20 gal per acre is prefered, does a better job.
Depending on how deep the pocketbook is & how tough a weeds you have, a quart per acre would do more.
In any case, we all are required to read & follow the label, where all this info is contained.
--->Paul
Steve from Tn
05-05-2002 16:11:22
Mark, a quart mixed with 10-15 gals. of water should do the trick. I believe that I used about 26oz. of the Round-up Ultra last year. I was covering 6 acres with about 75 gal. of water. Round-up will not kill every thing. It will get most grasses. It is not too good on morning glories and rag weed. Check with your extension agent.
