Need help setting seeding rate on MM grain drill
Joel H.
05-05-2002 10:37:13
Have a MM grain drill and need to seed 3 acres of crp ground. Need to seed 2lbs. red clover per acre, 4 lbs. timothy grass per acre, and 2 1/2 lbs. orchard grass per acre. Don't have a clue where to put my settings as I don't have many lbs of seed to work with I need to get pretty close the first time. No owners manual with drill. Over the years through trial and error I have setting established for alfalfa in the grass seeder and oats in the grain seeder. Elevator man says to put red clover in the grass seeder and grass seed in the grain seeder. Does anyone have any idea how these seeds will feed in comparison to alfalfa and oats? And how much should I drop my settings? Thanks
JMS/MN
05-05-2002 20:09:39
 Re: need help setting seeding rate on MM grain drill in reply to Joel H., 05-05-2002 10:37:13
Are there any settings stenciled on the underside of the grain box lids? MM drills also have a low and high gear, obtained by removing and reversing two gears on each side-part of the drive system. If you email your mailing address to me, I'll send you a copy of the stenciled tables in my drill.
Ultradog MN
05-06-2002 05:09:34
 Re: Re: need help setting seeding rate on MM grain drill in reply to JMS/MN, 05-05-2002 20:09:39
Saw this post yesterday and knew you were the right man to answer it. How you been?
JMS/MN
05-06-2002 22:12:57
 Re: Re: Re: need help setting seeding rate on MM grain drill in reply to Ultradog MN, 05-06-2002 05:09:34
Hi, guy- been doing ok- tried a bit of farming in this late spring- plowed those two spots I told you about, and 'talked' you through the whole demonstration! Since you missed that opportunity to ride along (no time to give you notice) and I don't think we had the plow day at the threshing club- I have a couple acres of old pasture I could demo plowing for you on this summer- anytime you can get away on a weekend. Let me know if you're interested. Reply here if you don't have my number anymore.
