Old implement Help identify please
John
05-01-2002 19:28:25
name plate --Remmel Mfg. Co. Kewaskum, Wisconsin
The implement has two parallel 4" OD hollow rollers with 3/4' holes and what appears to be 1/4" rivets in between the holes. The rollers are on an approximate 15 degree angle above horizontal and rotate toward each other when driven through the bevel gears and 8" dia flat belt pulley. The rollers are about 5 feet long and the entire unit is mounted on a wrought (cast) iron frame and 10" dia cast iron wheels. Is it a corn husker? OR??
Will photo tomorrow and include link. Thanks, John
Alvin NE WI
05-02-2002 19:01:44
 Re: Old implement Help identify please in reply to John, 05-01-2002 19:28:25
I would say you have a corn husker. They also made a 4 roller model. When new or being used there were also small pins inserted into the rollers which had small hooks on, to have a more aggresive bite on the corn husks. I have a 2 roller model in my possesion.
Alvin NE WI
05-02-2002 19:00:47
taylor Lambert
05-01-2002 19:42:48
I beleive it may possibly be a sugar cane press we have smaller units here but i have seen a few on big farms that were about that size.
JT
05-01-2002 19:30:42
sorry for the duplicate postings.
