New Old implement Help identify Please
John
05-01-2002 19:26:22
name plate --Remmel Mfg. Co. Kewaskum, Wisconsin
The implement has two parallel 4" OD hollow rollers with 3/4' holes and what appears to be 1/4" rivets in between the holes. The rollers are on an approximate 15 degree angle above horizontal and rotate toward each other when driven through the bevel gears and 8" dia flat belt pulley. The rollers are about 5 feet long and the entire unit is mounted on a wrought (cast) iron frame and 10" dia cast iron wheels. Is it a corn husker? OR??
Will photo tomorrow and include link. Thanks, John
