JD plow max speed
doug vose
04-29-2002 13:37:32
I am getting a JD plow, i dont know what model it is, but it has rope trip drop, 2 bottom, rubber tires. I am going to try to put it in the back of the truck, but if it wont work that way i will need to two it behind the truck. Does anybody know the maximum speed for this plow. The tires are truck tires rated for 60 mph, but i will not even go near that fast, it was just greased so the lubrication is no problem.
thank you
doug
Leroy
04-30-2002 19:18:11
 Re: JD plow max speed in reply to doug vose, 04-29-2002 13:37:32
Borrow a trailer, DO NOT tow, Will wip at 5mph and no bearings, would tear the wheels up
ET
04-30-2002 06:48:18
That plow should fit in a full size pickup with no trouble. You might neen to take off the drawbar to close the tailgate. I just had a 4B plow in my truck and I have hauled NO44 plows also. When you get it in use the levers to drop the plow down on the bottoms so it won't roll.
ET
04-30-2002 06:46:32
paul
04-30-2002 05:15:22
Ohmygosh, didn't bother reading this thread because I thought it would be about speed while in the ground.....
Don't tow it any distance at all. You won't get over 10 mph, if that!!! It will slap back & forth something aweful.
No one has mentioned - those trip plows are just that - what if it flops down into 'plow' postion on a bump in the road? Could make quite a mess.
Disassemble & put the pieces in your truck if nothing else, that's how they did it here before trailers became widespread.
--->Paul
Jerry D in NC
04-30-2002 04:21:14
Try U-Haul and see what they would rent you a trailer for. Last time I checke you could get the 4x8 utility type for around $12. Not even worth the risk of doing it any other way and it will be easier to load and unload than the truck
J.D. Putt Putt Guy
04-29-2002 18:36:08
Doug, You would be better off finding someone with a double wide snowmobile trailer that you could use(preferably one that tilts so that you can push-pull the plow on) if the plow won't fit in the back of your truck. Safety is everyone's business. Just my 2 cents worth.
J.D. Putt Putt Guy
04-29-2002 18:35:15
chuck
04-29-2002 18:04:12
don't consider towing a plow any distance behind a truck, you can't see it and an old plow wouldn't be safe a road speed over 10 mph.
Josh
04-29-2002 15:56:36
I'd try hard to fit it in the truck. The pull type plow I have "whips" back and forth real bad if you go more than about 10.
Josh
04-29-2002 15:54:41
Greg S
04-29-2002 14:40:53
Doug,
Old farm implements weren't meant to be towed at any kind of speed. The plow I use (six bottom 16" has a label on it that says not to tow in excess of 10mph.
