JD trip plow, cant get rim off axle!
Tom
04-27-2002 11:25:57
Old JD plow, don't know what model. 2 Bottom mechanical lift. The only numbers I found on it were, I believe, part numbers. 612 and 613 on the long frame pieces, 769 on the gear box lever arm, 9302 on the hitch, 066L18 by the discs, and D987A on the gearbox. I think the serial # is 15452. I cant get the rim off the axle (gear box side). It slides about an inch and then stops abruptly...I can't figure out what it is catching on. Thanks for any help!
Tom in MN PS It is snowing today, and this weather is driving me out of my mind. February was nicer than March and April....compounds my frustration at not being able to chang a silly tire!!!!!
Bob Collins
04-27-2002 13:41:39
 Re: JD trip plow, cant get rim off axle! in reply to Tom, 04-27-2002 11:25:57
Tom, You are not the first guy to have trouble with this, with the nuts that hold the grease cap and the cap removed, put a large puller against the end of the axle shaft and hooked to the hub of the wheel. Apply some pressure and thump the back side of the hub as close to center as possible. The wheel is on a tapered bearing (wheel box) and drives the lift clutch with three cast on lugs or keys, they get stuck pretty tight but proper persuasion should pop it off. That is a number 52 plow you have. Bob
