Switchgrass????
Mark
04-24-2002 17:55:47
I burned a old field off in March. The field hasnt been planted in years. The old grass grew back 3" or so. I plowed and disc the field. I planted the switchgrass seed with a cultipacker and it rained immediately after the seed was planted. There were clumps of the sod that I could not bust up with the disc. My question is should I still be ok or is the old grass going to grow back and choke out the switchgrass? I plan on mowing above the switchgrass all summer to keep weeds down but I was told that the old grass will give me trouble because I didnt use roundup on it before I disced it. What do you guys think?
Thanks Mark
CraigfromMO
04-25-2002 06:01:59
 Re: Switchgrass???? in reply to Mark, 04-24-2002 17:55:47
You are probably in trouble. I am assuming the old grass is fescue and discing it will only make it come back stronger. There is chemical called Plateau that you can spray that will kill the fescue, but not the switchgrass. Plateau cost $300/gallon, but you only need 4-6 oz per acre.
when I convert fescue to warm season grass I spray roundup in the fall, burn in late April, drill the seed in May, and spray Plateau a two weeks or so after planting. It has worked for me.
