Putting in a water line
Jerry in Pa
04-23-2002 13:33:05
I am going to run anywhere from 800 to 1200 feet of water line from a well at my house out to some pastures and surface the water with frost free hydrants. Any ideas on what type of piping to use? I am planning on renting a ditch witch for the trenching. Everywhere around here want 200 bucks a day!! How fast can you dig with a ditchwitch?? Its the 3 foot deep model on wheels.
Also, I have to go under a sidewalk as well as an old set of railroad tracks. How do you dig a hole under these things.?
I already have a drain pipe going under the tracks and could just run the water line through that if I had to but would like to know if there is another way to do it?
Any ideas???
Thanx,
Jerry in Pa
jal-SD
04-23-2002 14:37:09
 Re: putting in a water line in reply to Jerry in Pa, 04-23-2002 13:33:05
Jerry, I'd recommend "poly" pipe. It comes in rolls & is fairly easy to work with. Does your pump have the capacity to push water that far? Head loss in the pipe for that far could be a problem-you might want to go w/a fairly large diameter, which will be more costly, but give less resistance for the pump. In our part of the country, you wouldn't be able to bury it only 3' deep to prevent freeze up-we have to go at least 5 1/2'. We require contractors to bury it 6' to the top of the pipe. To get under sidewalks, roads, & railroads w/small diameter pipe, often contractors use a "hole hog", which pulls the pipe through using air pressure. Also, RR's in our area require all liquid crossings to be cased. Really spendy to do this. (My $0.02 worth. jal-SD)
