John Deere 999 planter need info planting corn monday!!!!!!!!!!
Darren Pulket
04-19-2002 18:09:03
Hey guys i'm good with tractors really good but i got an implement now and have little to no clue its a John Deere 999 planter it was last used 4 years ago to plant corn and did great job i oiled the chain then greased it and the axels and moving parts i oiled also but the thing is the plates turn good but do i need to do anything to check if the seed corn will go in the ground or will it just drop it in with no probs with that indication. Darren thanks for the help
Ralph Ia
04-19-2002 19:58:52
 Re: John Deere 999 planter need info planting corn monday!!!!!!!!!! in reply to Darren Pulket, 04-19-2002 18:09:03
Darren, There are seed tubes with valves in them below the plates that need to be opened. Thats what the wire did with the buttons and made the clicking sound. And then the seed would be dropped in hills. Those seed valves need to be opened to let the seed fall. It's been a long time but I think that in the center of the planter you will find a foot pedal with a S shaped arm on it. With this arm hooked to the rockshaft, push down on the pedal to over center and that should hold the seed valves open.
Fudd
04-19-2002 19:36:20
My Dad would pull the planter across the farm yard where the ground was hard and the corn would lay on top of the ground where he could see how far the space was and how many kernels to the hill.
fm..
04-19-2002 18:26:40
Jack up your planter and set the frame up on blocks. put some seed in, and set a cofee can under the openers. Turn the wheels. If corn drops out, everything is good. if not, you probably have the wrong plate. You can figure out what the outside measurement of your wheel is and figure out what your seed spacing would be, too.
David B
04-19-2002 18:26:27
You need to have seed plates that fit the size of the kernal of corn. The corn is graded and has the information on a tag or on the bag to tell you what number plate fits that corn. Also there are lots of different setting that control how fast the plate turns in relation to the ground, this is how you control the population of the seed. Pretty simple with just a couple of things that need to be checked and set as needed
