JD 24T baler
Tom
04-17-2002 15:32:17
Will synthetic plastic twine tie properly in a John Deere 24T baler? Any recommendations on type of twine?
Jerry D in NC
04-18-2002 19:22:28
 Re: JD 24T baler in reply to Tom, 04-17-2002 15:32:17
Tom,
Your baler will use the twine fine but will need adjustments before it goes out the door. tension on the twine disc and feed system will need to be set up for the plastic twine. Some folks are very lucky and can switch back and forth between the types of twine but the knotter do not always cooperate. If you want to run plastic twine then call a baler mechanic before the season gets in full swing and have him set it up.
Fudd@Work
04-17-2002 19:18:38
I use the plastic twine in my 14T without problems. Plastic was in it when I got it.
JD70Jim
04-17-2002 18:15:58
I would say yes. While I use a 337, the knotters haven't changed since the 1st 14t. You will need a different twine holder (or some other part) in order to convert to plastic, as there is a slight difference, but the conversion isn't hard and shouldn't be expensive. My 337 uses the orange plastic twine, without problems.
