PTO latch pin
Bus Driver
04-06-2002 16:53:27
On the yoke that slips onto 540 PTO shafts, there is typically a spring loaded pin that latches the yoke to the PTO shaft. I had one that almost came off in use. It was properly latched when put onto the tractor. The latch pin was beat all to pieces and difficult to remove. Found that it was just mild steel and made new one on the lathe. Haven't used it yet. Would have guessed that these pins are hardened, but then figured that the pto shaft would get beatup fom movement of a hard pin. Anyone experinced this problem or found hardened latch pins used?
dave s
04-06-2002 18:18:20
 Re: PTO latch pin in reply to Bus Driver, 04-06-2002 16:53:27
Yea, I lost everything on mine, spring too.I did however get a replacement that was inexpensive
