John Deere 7000 planter
John W.
04-05-2002 17:46:00
Hi , Does anyone know a easier way to remove the wheels on JD 7000 planter. I need to replace both tires. Appreciate any advice, thanks John
JMS/MN
04-05-2002 21:33:02
 Re: John Deere 7000 planter in reply to John W., 04-05-2002 17:46:00
I'm assuming your two wheels are mounted in the same manner that mine are on my 8-30, and you have a jackstand under the hitch where it mounts to the frame, and thus it will tip over backwards if you remove the wheels. Just leave it hooked to the tractor drawbar, block up the frame, and release pressure on the lift cylinder. Remove the large bolt going through the side frames on either side of the wheels. With the wheels away from the planter, you can unbolt the hub from the wheel so it fits in a tire changer.
