JD Plow Hookup
Mark
04-04-2002 19:46:18
I have an old JD 2 bottom plow, 1940's vintage. It has a fork on the hitch with a 5/8" hole. The spring mechanism is on the plow, but I am missing whatever piece it is that hooks up to the tractor. The fork won't go over the drawbar of the JD B I am using. Had to make a thinner plate and bolt to the drawbar to use the plow. What is this piece called that I need? Does anyone have one they would want to get rid of?
Thanks for any help.
Mark M.
Carthage, MO
Mark
04-05-2002 10:17:07
 Re: JD Plow Hookup in reply to Mark, 04-04-2002 19:46:18
Thanks for the help guys. I knew there was a mechanism for when you hit a rock. The spring and pocket for this device is on the plow. It sounds like I need a "J hook." I just didn't know what it looks like or what you call it. I will try Deere first.
Mark
ET
04-05-2002 08:59:34
If the plow is a mechanical lift it should take either the twisted clevis mentioned below or a
flat clevis that either bolts to the drawbar or some JD clevises use a drawpin. If the plow is a hydraulic lift the it may have the spring loaded knee knocker hitch that disengauged the clutch when you hit somthing. That one uses a comon straight clevis held to the plow with a bolt through a small fork.
Jhill
04-05-2002 08:48:12
I believe there should be a J shaped bar on the plow. The short end goes thru the clevise on the plow and the long end goes back thru a sliding bracket further up the hitch. You put the bottom of the j thru a clevis on the tractor then the long end goes under the sliding bracket and a pin holds the sliding bracket. When you hit a rock the spring under the hitch lets the j bar slide foreward and release from the tractor clevis. It's hard to describe. Hope this helps
ET
04-05-2002 09:02:41
 Re: Re: JD Plow Hookup in reply to Jhill, 04-05-2002 08:48:12
That J bar was still available fror JD a year or so ago.
Jhill
04-05-2002 10:12:07
 Re: Re: Re: JD Plow Hookup in reply to ET, 04-05-2002 09:02:41
Glad to know that i need one for another plow I have.
Jhill
04-05-2002 10:11:03
ET
04-05-2002 09:01:49
ATTENTION BOB COLLINS!
04-05-2002 05:55:47
Bob, can you answer this? Ray
04-05-2002 05:54:50
RayP(MI)
04-05-2002 05:35:49
If it is what I'm thinking, the fork is horizontal right? If that is the case, then there's a bolt with a sleeve going horizontally through the fork, adn then you use a conventional clevice - usually made of round stock to connect to the drawbar.
Or, is the fixture on the plow a trip release mechanism - then you need a twisted clevice.
If you could post a picture, or give a model number - and Bob Collins shows up, he could be more help. He knows about JD plows!
R
Bob Collins
04-06-2002 05:56:03
 Re: Re: JD Plow Hookup in reply to RayP(MI), 04-05-2002 05:35:49
Ray, Thanks for the vote of confidence. These answers are all good, also I answered this question for mark a few days ago (see below about 3 pages.) I think he needs the L or J shaped part # 19015A Hitch release hook. This seems to go along with the description as I visualize it. Can you imagine how boring this would all be if John Deere had only made one plow and one style hitch etc.?
