PTO GENERATORS
JD 770
03-25-1999 11:45:19
Are Winco Pto generators any good?
carl
03-25-1999 12:01:58
 Re: PTO GENERATORS in reply to JD 770, 03-25-1999 11:45:19
I have a winco generator that works good on the farm for temporary power outages. I use it a couple times a year and it has worked real well. If you are going to use it frequently get a continuos use style they are more expensive than farm duty generators but will hold up to long term use
JD 770
03-25-1999 12:10:29
 Re: Re: PTO GENERATORS in reply to carl, 03-25-1999 12:01:58
What long term kind of generator?
Winco any good 12kw pto driven?
carl
03-26-1999 16:10:25
 Re: Re: Re: PTO GENERATORS in reply to JD 770, 03-25-1999 12:10:29
It should say on it somewhere if it is continuos or not which means it can run for long periods without getting hot. Mine is a 15kw winco it can run the milkmachine pump and timer bulk tank cooler and agitater and the lights anything more trips its circuit breaker. I am happy with mine and have had no trouble with it
