NH 462 Disc Mower
Mike F
04-02-2002 09:42:45
On a NH 462 disc mower after you remove the disc how do you remove the bearing cover that goes on the drive gear?Are there bolts?The bearing cover is listed as #17 in the parts book.
Thanks
Mike
NH
04-02-2002 19:32:20
 Re: NH 462 Disc Mower in reply to Mike F, 04-02-2002 09:42:45
I hate to tell you but you have to split the bar ,yes take out all of the bolts around the outside and the big allen head bolts in the middle and then you can get to the bolts that hold the bearing housing. I have replaced the bearing from the top by cutting it with a torch very carefully and taking the balls out and then the inside and outside race will come out and the slag from cutting will fall on the gear and can be cleaned out then replace bearing if that is all that you need to do. Hope this helps.
Steve
04-04-2002 04:40:17
 Re: Re: NH 462 Disc Mower in reply to NH, 04-02-2002 19:32:20
Mike, everything NH has told you is correct. I need to add one more thing. When removing those big set screws, you HAVE to loosen them all together!! About 1/2 turn for each one. If not, you will bend the housing. This is a royal pain, but it MUST be done that way. Someone may tell you they took them out one at a time, but this is incorrect. Steve
Mike
04-03-2002 05:14:40
What is the best way to remove the 14mm allen bolts??
Mike
NH
04-03-2002 19:27:18
 Re: Re: Re: NH 462 Disc Mower in reply to Mike, 04-03-2002 05:14:40
I went to the parts store and bought a allen wrench that was good and guaranted and clean the holes out good and put a cheater bar on it and screwed them out then when you put it back together be sure and torque the allen bolts and tighten from the center out evenly while watching the big o-ring that seals the outside. Hope this helps
Mike F
04-03-2002 04:51:04
Thanks,I have to spilt the case to replace a gear,so I guess I'll replace it too.
Thanks
Mike
