Tractor Loader found in wood lot!
GrassGrower in
04-01-2002 18:51:38
I found an old hyd loader in a farmers wood lot.He says it will fit the n series fords.I have used and seen a lot of loaders but I can't make much sense out of this one fitting a ford. It had a very ledgeable ID plate .It reads thus:
DA-WEST Hydraulic Agricultural Loader
Ser.HAL 7044
Dasis-Westholt Mfg. Inc.
Wichita,Kansas
Can any one help with info ?
JoeK
04-03-2002 14:28:10
 Re: Tractor Loader found in wood lot! in reply to GrassGrower in Mo, 04-01-2002 18:51:38
Some of the early Ford/Fergeson loaders were very different from what we commonly see.There was no loader"frame" mounted to the tractor.Loader"arms"
and linkages mounted to brackets under the rear axle and on front axle.Loader was operated by the tractors 3pt,and a small "booster" cylinder in the rear.The main lift arms on these were made of pipe and plate gussets,not like the large tube or box beam arms seen today...Maybe this is the type of loader you have found....There is/was a Westholt Mfg in Wichita that was an EPA cleanup site a few yrs back,unknown if related.
