McCormick 200 Manure Spreader Parts
Steve Adair
04-01-2002 06:47:32
Does anyone know where I might be able to get parts (new or used) for the above spreader? Specifically, I am looking for the right bushing that the shaft of the lower rear auger goes through. Thanks in advance!
Tom-Pa
04-01-2002 10:32:00
 Re: McCormick 200 Manure Spreader Parts in reply to Steve Adair, 04-01-2002 06:47:32
If it is the spiral shaft bushing, the part no. is 3-321-SA. If the upper cylinder shaft bushing the part no. is 3-317-S. If the lower cylinder shaft bushing, the part no. is 3-312. I do not know if they are available any more, you would have to check with the Case/IH dealer. Other wise, you would have to measure the shaft and take the bushing to a machine shop and have one made to fit the shaft.
Good luck.
Tom-Pa
Steve Adair
04-01-2002 14:15:45
 Re: Re: McCormick 200 Manure Spreader Parts in reply to Tom-Pa, 04-01-2002 10:32:00
Thanks for the reply. The owners manual says it is the right spiral shaft bearing. At least that is what it is called under the lubrication Guide. I do not have a parts manual so I am not sure if that is the correct name. It is a cone shaped bearing/bushing that the shaft of the spiral is inserted in. From your reply I assume that this would be part # 3-321-SA. It appears the bushing/bearing has broken and is missing a 1/2 inch section out of its side. This allows the shaft and attached sprocket to drop and the spiral drive chain comes off. I will try an IH/Case dealer but I have my doubts that the parts are still manufactured. Thanks again for the reply, if you have any other ideas let me know.
Tom-Pa
04-02-2002 09:21:00
 Re: Re: Re: McCormick 200 Manure Spreader Parts in reply to Steve Adair, 04-01-2002 14:15:45
Steve,
I have the parts manual/setting up instructions. You can also ge a copy from the N-Newsletter. Go to www.n-news.com, and then click on archives.
If you have any further questions, go ahead and email me. Tom-Pa
