Need help restoring a JD 2 row cultivator
maurice
03-22-2002 18:35:02
I recently acquired a JD front mount cultivator for my 1950 JD B. Need any pictures or advice on attaching this to the tractor. Any help is appreciated!
RossMN
03-23-2002 20:12:20
 Re: Need help restoring a JD 2 row cultivator in reply to maurice, 03-22-2002 18:35:02
Try this website Link he has one on a late styled B and has a few diagrams your Deere dealer should be able to get a owners manual after you find what model it is
MRC
03-23-2002 17:46:48
Write down as many of the numbers as you can find from the parts of the cultivator. Take this to the nearest JD parts place and have them look up the numbers to see which models they fit. From this you can narrow down which exact model you have. Then order the operator manual and parts manual for that model. It will cost $10 or so at the most but it is money well spent.
Fudd
03-22-2002 19:28:28
Hope this helps some. The cultivator slides up on the plate on the front then you swing each side up against the frame of the tractor and bolt it on each side. There are arms that bolt to the rockshaft that the lift bars attach to. Good luck. This is a 41 hand lift but yours will be similiar. That's me many, many years ago.
