Rotary hydraulic cylinder not holding hoe steady
Matt
03-23-1999 18:17:47
I have an older Mid-Western/Davis backhoe attatchment that is equiped with a rotary or orbital swing cylinder. The hoe will swing left and right OK but wont hold steady in place and swing away on gravity. The barrel has two hoses for left & right swing and what appears to be a common return line back to valve section. Would check valves installed in these swing hoses stop this problem or cause other flow problems? What possible causes and remedies would be suggested. Any advice would be appreciated.
Big Dean
03-26-1999 22:54:08
 Re: rotary hydraulic cylinder not holding hoe steady in reply to Matt, 03-23-1999 18:17:47
Matt the seals are bad in your rotary cylinder the Massey Ferguson backhoe used the same cylinders the seals are a little trickey to put in it easy to nick them when you slid the shaft back in I have changed a lot fo them if I can be of further help just send me an e-mail
Mike Ables
09-18-2006 14:28:41
 Re: Re: rotary hydraulic cylinder not holding hoe in reply to Big Dean, 03-26-1999 22:54:08
I have rotary cylinder that has the bottom trunion broke off.where can i find one?
ajay harsulkar
03-16-2000 06:29:29
 Re: Re: rotary hydraulic cylinder not holding hoe steady in reply to Big Dean, 03-26-1999 22:54:08
send information
