Info on Old Case Hay Rake
Robert
03-17-2002 17:38:33
I would like to restore an old 4 bar Case hay rake which my father purchased about 1950. It is ground driven on two rubber tires. Bars and wheels are orange; frame is green with faded J.I. Case decal. I've found Case orange paint, but not Case green. Can anyone recommend a paint code that is close? Also, would be interested to know what model the rake is, and if owner's manual is available.
Thanks in advance.
DAVE S.
03-18-2002 15:43:18
 Re: Info on Old Case Hay Rake in reply to Robert, 03-17-2002 17:38:33
I have what is probably the same rake, but mine had a green frame, red bars and yellow rims. I know it sounds bad,but that is to be original colors.A lot of the older equipment was painted up with a three color scheme. The decal was on the upper side of the frame.It also has a cable on pulleys down to the wheels for adjustment.I don't know the mod. # either but I still use this rake every year. Good Luck w/ the rake.
