No.27 IH mower pitman
tomyasnowski
03-15-2002 09:26:47
I am going to rebuild a pitman, and noticed there
is a bolt going thru the wood near the latch end
of the pitman. It is in opposite directin of the hardware bolts on that end, but it does not seem to hold anything. What is the purpose of this bolt? The replacement pitman I bought does not have this hole pre-drilled either
Thanks
Tom
jal-SD
03-15-2002 12:15:00
 Re: No.27 IH mower pitman in reply to tomyasnowski, 03-15-2002 09:26:47
Does it have a flat washer on either side? We used to drill a hole in the ends of the wood sticks on our MH #7 mowers & bolt & washer 'em to help the stress @ ends. Used to put up 180 A of alfalfa 3X per year & would break the sticks more often ifna they didn't have the exta bolts than we did if they had 'em. It seemed like the sticks wanted to split from the holes that hold the hardware on it & this seemed to help prevent that. (My $0.02 worth. jal-SD)
Tom Yasnowski
03-15-2002 12:21:53
 Re: Re: No.27 IH mower pitman in reply to jal-SD, 03-15-2002 12:15:00
Without taking it apart, It looks something proprietary-no quite like a bolt. might be a washer on one side,can't remember. It must be for
stress because it doesn't fasten anything to anything; it is just "there"
Thanks
Tom Yasnowski
03-15-2002 12:20:38
Thanks
Dick Davis
03-18-2002 03:51:49
 Re: Re: Re: No.27 IH mower pitman in reply to Tom Yasnowski, 03-15-2002 12:20:38
Some pitman sticks had two flat washers and a rivet to help contain the stress previously discussed.
