Wagner WM-4 loader control valve
Jamie King
03-10-2002 06:33:31
I have a Wagner WM-4 front-end loader on our 1953 Golden Jubilee. Slight problem with the loader control valve. Often when you lower the loader arms quickly, this starts to activate the bucket dump valve. It seem to be worse when the engine is running at higher RPMs. I am thinking that the compression spring in the dump bucket valve is weak/worn-out. I had the valve apart, thinking I would find a broken spring, but nothing much else seemed bad. I replaced the O-rings while in there, but had no effect. Any ideas would be appreciated. Also, any ideas on where to get a service/parts manual for this loader (WM-4) would be great. Thanks.
