Removing Superior Loader
Dave
03-08-2002 04:52:54
I bought a Ford 860 with a Superior front loader on it last year. I find that the front end is constantly sinking into the mud and causing me to get stuck. I have 6x16 front tires, that I'm considering replacing with larger ones. But before I do that, I'm wondering how difficult it is to detach and reattach these loaders. Maybe I could just attach it when I need it.
Thanks for any input.
JMS/MN
03-08-2002 10:24:49
 Re: Removing Superior Loader in reply to Dave, 03-08-2002 04:52:54
If it does not have built-in stands (check with your dealer if unsure), then build an A-frame hoist to hang it from for unhooking from the tractor. Use an adequate winch or comealong to lift and support it while it is off the tractor. Use hydraulic couplers on the hoses for disconnects if not already equipped as such. Can switch it in a matter of minutes if you are set up properly and safely.
