ShepFL
George8NFL
03-07-2002 03:03:38
Hi How do you finish up after you disc your place?
I assume you are in Fl I'am in central Fl (sandy ground) Just got me a disc for BD. Now I need to get the yrd in shape. Need a lawn upgrade and would like to grow some feed for possible cow ss and also to green up the back few acres. Have myself a 518n. Figure I could disc the place How many passes? then level with a chain link fence whatdaya think?
Thanks in advance
ShepFL
03-08-2002 06:25:37
 Re: ShepFL in reply to George8NFL, 03-07-2002 03:03:38
George -
I am swamped right now. Will post details later this weekend. Just wanted to let you know I seen your post. I am located in Sanderson, FL. Dead middle on I10 between Jacksonville & Lake City.
kraig WY
03-08-2002 05:49:39
If you want to finish up after discing you should use a harrow. You can make lots of passes with a disc but a harrow will take less time. I start with a chisel plow, disc, then harrow. For a real finish I use a rake I made from a large screen, and hundreds of railroad spikes driven through and welded to the screen. Cheap but works. I can even rake the lawn without tearing up the sod.
George8NFL
03-09-2002 09:46:29
 Re: Re: ShepFL in reply to kraig WY, 03-08-2002 05:49:39
Actually what I have is called a Harrow according to the label on it. Got it at Tractor Supply 6 1/2' 18" blades. I was told that is what they disc/harrow are called in this neck of the woods.
Tried it out yesterday works great but need to change trans fluid before I get to rambucktious.
Thanks
Anyone Please
03-07-2002 15:50:25
ok
George8NFL
03-07-2002 15:48:34
Thanks
bob
03-08-2002 09:55:17
 Re: Re: ShepFL in reply to George8NFL, 03-07-2002 15:48:34
I also disc and then insteadof cyclone fench i use an old type bed spring if you have sand should work good i live in Ia. and it is heaver soil
