Corn Planter
Big J
02-23-2002 20:39:05
What is the best corn planter to use with a Gleaner E? Never had an E before. It is a 2 row corn head if that helps. If anyone has any suggestions please let me know.
Chuck
02-25-2002 12:19:56
 Re: Corn Planter in reply to Big J, 02-23-2002 20:39:05
In central Mo 4 row planters can regularly be bought for less than $50. 2 row 3 point plnater run several hundred. 2row corn heads will work on anything even one row planters. I saw a 6 row JD sell for $15.last month.
Chuck
02-25-2002 12:18:10
Tim(nj)
02-24-2002 15:14:36
Get a 1240 or 494A 4-row, set up for 38" rows. I just bought a 494-A in good working order for $100. Your A needs to have a Powr-Trol plug to work the wheel-lift cylinder on the planter. Flexiplanters are not an option without 3-point hitch.
Paul Geer
04-12-2002 18:50:21
 Re: Re: Corn Planter in reply to Tim(nj), 02-24-2002 15:14:36
Hi I am looking for the fertlizer boxes for a 1240. I am in Belmont, MI.
I can be reached at 1-800-DRY-ROSE. If you have'nt guessed it by now we are a flower farm...Paul
John A .
02-23-2002 21:15:21
For simplicity a set of JD 71 flex- planter units
should work well for you. Whether you are planting in the bottoms, or on the tops.
Big J
02-24-2002 10:35:44
 Re: Re: Corn Planter in reply to John A ., 02-23-2002 21:15:21
About how much would it cost? Could a 1950 John Deere A pull it?
