Spreading dirt/salt mix using front end loader
robertd
02-17-2002 09:43:39
anybody try modifying their loader buckets slightly to bolt on some type of metal screening so you can just drive along and tilt the bucket up and down as you drive thereby spreading the somewhat moistened sand evenly on long,icy driveways in the wintertime?i can't afford the $3,000 for a nice conveyor type sand spreader for the back of my pickup truck.besides,my truck is only a half-ton model.most of the cheaper plastic spreaders that mount on truck tailgates,are designed only for free-flowing materials such as straight rock salt.sand(usually somewhat moist)will just plug this type of spreader i bet?although,they do offer vibration kits.....i'd just assume trying to try the front-end loader idea.helpful comments please...thanks,rob.
John S-B
02-17-2002 15:01:09
 Re: spreading dirt/salt mix using front end loader in reply to robertd, 02-17-2002 09:43:39
Robert I used to plow snow and what we used was a nice heavy duty walk behind fertilizer spreader. They are about fifty bucks and should hold fifty #. The rotary type spreads about 8-10'wide in a pass, just right for a driveway. If you have dry sand you can mix it with the salt. Different brands of salt have different sizes of salt crystals, try to find some that are small so they'll spread more evenly. Make sure to keep the spreader clean and lube it often with wd40 or it will corrode it.
