what size Brush Hog
Bill
02-13-2002 12:33:36
what size brush Hog will my John Deere model 720 handel. Thanks Bill
Gordon
02-14-2002 10:31:00
 Re: what size Brush Hog in reply to Bill, 02-13-2002 12:33:36
The size of a mower is based on 5 hp per cutting foot. A 6 foot mower needs at least a 30 hp tractor. you could go as high as 10 foot depending on what you are mowing, heavy brush or regular grass.
Alabama
02-14-2002 08:26:12
Practically speaking...what are you planning on doing with it? 59 horse power can pull a lot of bush hog. If you go with a 3pt then your limited to the size of the tractor not the pulling power of the tractor. If you have a lot of field with a pull type as large as you can afford would be fine. If you need to do more presise cutting under trees etc. A 3pt may be what you want. I cut 42 acre of field very nicely...with a pull type 6ft bush hog brand using a Farmall "M". Your JD sould pull whatever you can afford. I would stay away from to large because it cost more to maintain and may require a larger trailer to tow it.
Nut Sack
02-14-2002 05:13:39
Call your local dealer, he will be happy to help you with this problem.
Jerry (AL)
02-13-2002 17:40:15
A lot depends on what you are going to be cutting. Brush takes more HP than say clipping pastures.
Your 720 has 59 HP. I have a Massey with 54 HP and I pull a six foot. It's not because it won't pull a little bigger but then you have to lift it.
I would say if you wanted a light duty, I might go as high as 8-9 foot.Then the bigger you go you go to the dual spindle jobs after about 7 feet.
There's a site called bushhog international where they will give you HP requirements for size. You can run a bigger drawbar type than you can a 3 point lift type also.
Also ask the question of yourself "are you going to be traveling on the highway any?"
Your tractor would pull an 8 foot with no problem but there are a lot of other questions you will want to ask yourself.
Richard
02-13-2002 16:19:57
A 720 diesel lives and works back behind my place. Saw it hooked to one of those bat wing bush hogs. So at least a 14 footer would be my guess.
