JD Mod. # 20 MT-Belly Mount Sickel Bar Mower Question???
Mark Hendershot
02-11-2002 17:49:44
I have figured out my JD Mod# 20 Sickle Bar Mower is the Belly Mount type for the JD MT Tractor. It is hung off the engine area with a Clamp and several brackets. The Mower is ran by a drive shaft drivin by a Pulley & Belt off the PTO Shaft. The Pulley is about 10 inches in dia. and has a spline with a bolt to make it tight. This Mower seems to weight around 400-500 lbs. Dose anyone have a picture of one assembled or know the Number for the Manual. I have it all together except the brackets to hang it with. There are a lot of pulleys for a cable set up which I think it is for raising and lowering it with the lift bars. Any help would be great! Mark H.
Ol Snuffy
02-13-2002 17:57:49
 Re: JD Mod. # 20 MT-Belly Mount Sickel Bar Mower Question??? in reply to Mark Hendershot, 02-11-2002 17:49:44
Talk to your local John Deere dealer. He will be able to get you an operators manual. In it you will find mounting instructions and ilustrations, as well as set up information. Good Luck
Mark Hendershot
02-13-2002 18:26:05
 Re: Re: JD Mod. # 20 MT-Belly Mount Sickel Bar Mower Question??? in reply to Ol Snuffy, 02-13-2002 17:57:49
Bill sent me some pictures of it showing how to set it up and what the parts are for. Thanks, Mark H
