Jd # 8
shawn
02-11-2002 15:04:59
I have a JD # 8 sickle bar and I blow the front seal and didn't notice. This caused me to smoke a bearing ( one or more have not looked) My ? is how easy is it to rebuilt the gear box and were do I get to parts? thanks
ET
02-12-2002 04:43:35
 Re: jd # 8 in reply to shawn, 02-11-2002 15:04:59
The bearings are all comon sizes but the one behind the flywheel has the seal made right onto the bearing. Make sure the flywheel is tight on the splines.
Clem
02-11-2002 20:27:18
JD has the parts but it's cheaper to buy the bearings and the seals at a bearing dealer. What you called a gear box is really a chain drive. Ther are two shafts in the drive. The top one is driven by the tractor PTO. Power is transmitted from the top shaft through a sprocket and chain to the bottom shaft and sprocket which has the fly wheel mounted on it and to which the pitman is connected. The chain drive runs in oil.
