Swap A/C Monoframe plow
WI Farmboy
02-04-2002 11:17:53
I have a A/C 5 bottom 2000 monoframe plow. It has shear bolts on the gusset plates so if you hit a rock it is 45 minutes to loosen the gussets to put in a new shear bolt. My cousin has a A/C 2000 monoframe with hydrolic reset. the frame is messed up. Could I switch the gussets to put on the hydro reset? Let me know.
Tim(nj)
02-04-2002 13:13:10
 Re: Swap A/C Monoframe plow in reply to WI Farmboy, 02-04-2002 11:17:53
Not familiar with the A-C plows, but I've seen it done to JD plows. You have to change the whole beam assembly from the frame down.
