Re: 7’ drag disc question?
eboor1995
11-30-2018 19:33:58
Here’s the picture third party image
JustIn Case
12-09-2018 08:06:21
 Re: 7’ drag disc question? in reply to eboor1995, 11-30-2018 19:33:58
Looks workable for what you want to do, a little lube and some time it may loosen up. May not be perfect but heck if the price is right...
eboor1995
12-09-2018 19:13:32
 Re: 7’ drag disc question? in reply to JustIn Case, 12-09-2018 08:06:21
I went ahead and got the disc its a David Bradley/Sears and Roebuck but the parts to make it fold are welded up in the full V position so it will work for what I need it to. I’m gonna plant 1.5-2 acres of pumpkins and gonna disc between the 8 foot rows to keep weeds down till they vine enough.
BushogPapa
12-07-2018 08:08:58
Dang good looking Disc.....!!
Leroy
12-01-2018 05:46:45
The working part is cut off in the picture but I agree with the others, probably rusted fast. Some had a crank for adjustment and Case had a model with a clutch simular to a plow so needed to know what type it was.Probably just rust but could also be worn parts that once you get it apart could be repaired.
DeltaRed
11-30-2018 20:45:31
Parts are probably just rusted from non use. Or could be wallered or bent somewhere,preventing it from moveing.A little cleaning and straightening would fix it.
