Need hydraulic cylinder advice...
Mike in Va.
01-29-2002 12:42:49
Hello Folks- My Case 450 crawler/loader has been out of service since last April. Finally got a handle on getting it back to work. In the meantime the bucket has been sitting on the ground with the hydraulic cylinders extended. The weather has rusted the pistons in places. I've been told that I can buff them with emory paper and keep grease on them. What advice do you have? I don't want to ruin the seals. Mike in Va.
bob
01-29-2002 13:03:10
 Re: Need hydraulic cylinder advice... in reply to Mike in Va., 01-29-2002 12:42:49
Mike i think real light emery and oil would work but if your cyl. are starting to rust it seems like chrome coating or whatever has worn thro emory and wipe clean and then oil later you can put grease for long setting periods hope this helps bob
Mike in Va.
01-29-2002 13:13:22
 Re: Re: Need hydraulic cylinder advice... in reply to bob, 01-29-2002 13:03:10
Thanks Bob, Never planned on having the 450 sit so long. Then after a while I quit thinking about it. Now I need to spend some time on it. I'll follow your adice. Probably need to have the pistons re-chromed before long... but then there is that engine rebuild too. It is blowing oil out of the valve cover breather.
