Renovating an old disc
trnut
03-14-1999 18:58:18
I have an old horse drawn disc which was converted for tractor use some time ago. She is showing some wear--The shafts are wobbbling in the bearing housings. I expect these are what is referred to as "white iron", but really don't know much about metallurgy. How would you fellows suggest they be restored?
Bret
04-04-1999 22:02:51
 Re: Renovating an old disc in reply to trnut, 03-14-1999 18:58:18
If it has wood bearings, you can make them pretty easy. Use dry hard wood, maple if you have it, and soak it in oil after you cut it to size and bore it out. Make sure you have a way to grease them after you fix it.
Sid
03-16-1999 18:31:24
I may be able to help you with the bearing spools and caps if you need some. We have several different sizes.
Ray
03-14-1999 20:06:11
they could have wooden bearing in them also. Ray
