Land plow
kevin
01-23-2002 05:14:10
what exactly is a land plow?? what does it do ??
thanks
Farmer-Gene
01-23-2002 17:57:02
 Re: land plow in reply to kevin, 01-23-2002 05:14:10
I think maybe you mean an on-land plow, it's a moldboard plow but the tractors rear wheel doesn't run in the furrow but stays up on unplowed ground its good for soft ground and you can run duals on the tractor if you want.
F14
01-23-2002 09:49:57
It's an implement for turning over ground. Used to be standard to plow a field to turn over last year's trash, then work the soil down with harrows into a seedbed, then plant. With herbicides and minimum till, they're not used much anymore, maybe every 4-5 years instead of every year. Link is to a picture of a typical trailer type plow.
