Plow points for backhoe bucket ?
rhudson
01-15-2002 12:54:11
just in last stages of building a 22" bucket for the Pel-Job mini-tracked hoe i just pruchased. would it be ok to use plow points for replacable cutting edges? can the points be welded on without affecting hardness or toughness of points? any suggestions? Thanks
F14
01-15-2002 13:07:08
 Re: plow points for backhoe bucket ? in reply to rhudson, 01-15-2002 12:54:11
It might work but...
The usual practice is to put stubs on the bucket, and replaceable hardened "teeth" that slip over the stub. On my light duty Woods, the stubs have indentations in them. New teeth are held in place by slipping them over the stub, heating the side with a torch and peening them into the indentations. When it wears thin enough to come off, it's time to replace it.
Welding the final "tooth" direct to the bucket will make them harder to replace as they wear. I wouldn't worry too much about taking the hardness out when welding them on unless they're really, REALLY short.
