Wain-roy back hoe
Paul, NH
01-10-2002 05:46:28
I've got a Wain-Roy backhoe Model WR120F Serial 112. Does anybody out there have any information on this, manuals, parts books or anything else. Previous owner was restoring and its in about 100 pieces. Need Help putting it back together!!!
Thanks, Paul
dadiv allard
05-17-2003 17:46:59
 Re: wain-roy back hoe in reply to Paul, NH, 01-10-2002 05:46:28
the original owners sons are still running a repair operation in mass. call them at 978-928-4258. I also have a problem with my wain roy maybe you father has run it to. it is the following. when i go along on level ground i can go at a good clip and shift and continue to go without any black smoke or a reduction in loss of power. however when i try to go up a hill at any speed i get a tremendous amount of black smoke with a loss of power and i cannot make it up a hill and the backhoe stalls out. any suggestions.
Unimog
01-10-2002 18:52:48
Paul, Wain-Roy is still in business making hoe
attachments and buckets. They are located in
either Fitchburg or Hubbardston, MA. I don't
have the phone number anymore but should be easy
to get from Ma Bell. Maybe someone at the factory
can give you the info you need.
Unimog
Paul, NH
01-11-2002 05:56:17
 Re: Re: wain-roy back hoe in reply to Unimog, 01-10-2002 18:52:48
Wain-Roy was bought by woods equipment. I called them but they said they don't have any of the old records.
Unimog
01-11-2002 19:05:19
 Re: Re: Re: wain-roy back hoe in reply to Paul, NH, 01-11-2002 05:56:17
It's been a while since I heard much about the
Wain-Roy stuff so the Woods buyout makes sense.
I have 2 Wain-Roy Rustler backhoe/loaders. Both
from the mid-60s with Ford 172 engines and a 4
speed Funk Rev-o-matic drive. My backhoe model
is F1441 which is the 14' hoe. Do you have just
the hoe or the complete machine? I'll check in
the morning as to the model number of the whole
unit as it's been a while and I've forgotten just
what they went by. I have a owner's manual and
maybe a shop one too so I might be able to help
with some pics or details.
Unimog
Paul, NH
01-14-2002 09:41:09
 Re: Re: Re: Re: wain-roy back hoe in reply to Unimog, 01-11-2002 19:05:19
I have just the hoe. Anything at all would be appreciated!!!! Paul
Chicken George
01-10-2002 06:51:59
Paul, I can't help BUT, I have a Wain-Roy Back hoe attachment, just the hoe part, not the tractor.
I am planing to attach it to one of my tractors,on a four point setup like ford backhoes.
I did a web serch awhile ago and they are still in business, tho'I think they only make a buckett quick attachment Is yours a crawler or a wheeled tractor? I have never seen one. Later Geo.
Paul, NH
01-10-2002 07:42:53
 Re: Re: wain-roy back hoe in reply to Chicken George, 01-10-2002 06:51:59
Mine is on a 1962 Ford 4000. It has special mounts that mount on the tractor. Don't know if they were custom built or not. The hoe has four attachment points on it. The base of the hoe sits on the lower two mount points then two arms close over the top two, and are held in place with two clamps to squeeze them down. Mine is in a bunch of pieces so I really need help figuring out how it all goes together. Thanks for the reply! Paul
Paul, NH
01-10-2002 07:48:28
 Re: Re: Re: wain-roy back hoe in reply to Paul, NH, 01-10-2002 07:42:53
George, If I didn't mention, yes its just the hoe part. Do you have manuals or anything for it??? Could you maybe send me pictures of yours?? Any help would be appreciated!!! Thanks Much, Paul
C.George
01-10-2002 12:57:35
 Re: Re: Re: Re: wain-roy back hoe in reply to Paul, NH, 01-10-2002 07:48:28
Paul, I don't have pictures/paperwork Mine is not that complicated two lift cyl's to lift the boom, one to lift the dipper and one to curl the buckett,one each for the stablizer pads two to swing the boom. pretty straight foreward maybe I can talk you through it. I have never had it on a tractor,I bought it a few years ago, and I just haven't had time to mount it. it sounds like your mounting is "ford" I have seen/used a "ford" 4500 Ind. T.L.B. keep in touch,Geo
Paul, NH
01-15-2002 06:17:04
 Re: Re: Re: Re: Re: wain-roy back hoe in reply to C.George, 01-10-2002 12:57:35
Hey C. George, What model # is your back hoe?
Thanks for all your help, and I will stay in touch. Paul
