John deere 346 vs 575 new holland
will t
01-09-2002 13:59:09
i have found a 346 jd hay baler that is in good shape and a new holland 575 that is about the shape. i have both dealers around me that has a lot of parts. what is the best baler of the two?
and what is a good price? the new holland is newer but about the same shape!
Wisconsin Ron
01-10-2002 20:20:36
 Re: john deere 346 vs 575 new holland in reply to will t, 01-09-2002 13:59:09
We own a 575, My uncle owns a 346. They are both larger capacity. The NH will eat more hay faster, but that might be due to the belt thrower. The NH will bale tougher hay too. They don't recommend a Deere if you have hilly land, or alot of waterways to cross. That is because the wagon hooks to the chamber on the deere, not a separate frame underneath. I have seen alot of deeres with cracked up chambers. Maybe deere has them designed different now. I think if you have flat land they would be allright. The NH parts are alot cheaper than the deere around here.
Tim(nj)
01-10-2002 15:48:57
You didn't say if they had throwers or not, but the NH belt thrower is a lot less troublesome than the pan type that JD uses. Around here, Deere balers hold just as much resale value as New Hollands. 575 are 1988 and newer, around here the going price is $8000 and up. (A contemporary Deere 348 would be priced the same) A good 346 (1970-81) will go between $2500 and $3500. 1970's era New Hollands bring less here, probably because they still had chain drive knotters and the 336-346 had gear drive.
B.C.
01-10-2002 10:41:02
I've had older stuff than that from both Deere and NH but I think the following still applies: It has seemed to me that the NH balers were easier to adjust and that those oscillating fingers worked better than the Deere auger. On the other hand it seemed like Deere's parts were available quicker and a little cheaper. You can get manuals for both pretty easy. Either one should have good resale. I lean towards NH. They both work.
smirkey
01-10-2002 05:55:19
I think New Holland is the better owerall baler, better pick up head, durability, resale value. but John Deere makes a nicer square hay bale for selling. the JD auger feeder is not as good in slippery material like fodder, straw, cane butts etc. the new holland will bale all of those better. just my opinion
