Rotary Mowers
Mark
01-03-2002 21:30:29
Of the 5 FT Standard Duty Mowers listed, which one does the best job of mowing grass?
1. BUSHHOG
2. SERVIS RHINO
3. WOODS
4. LAND PRIDE
5. HOWSE
6. KING KUTTER
Thanks for the help!
Kermit in SW MO
01-08-2002 03:42:41
 Re: Rotary Mowers in reply to Mark , 01-03-2002 21:30:29
I have a large Bush Hog used to cover large areas, and a 6 foot 3 point John Deere used to get into rough or tight areas the large unit can't get into. I've been happy with both. I agree with an earlier posting. Don't consider House. Sad to say I owned one for awhile. It was the worst balanced brush hog I ever saw. Was glad to get rid of it.
Scott
01-07-2002 15:51:49
Woods or Rhino are far ahead of the others. Howse should not even be considered.
Roy
01-06-2002 16:19:58
I am using a 7' Servis Rhino after owing many other rotary mowers and I am convinced it is the toughest out there. The main problem you will have with rotary mowers is the gear box. Usually the lower seal will be the first thing to go. Make sure you get a high H.P. rating on the gear box if you intend on cutting heavy brush.
Robert in W. Mi.
01-04-2002 15:10:11
If it was my Money, i'd spend it on a Woods cutter. Of the Cutters i've owned and used, The two Woods i have now have the been best. Robert
Jerry (AL)
01-04-2002 13:42:15
Woods is reputed to be an excellent mower but I've been told the price is higher. I have just bought a 6 foot cutter recently and I looked and compared Woods, Howse, Bush hog, and King Cutter. I chose the King Cutter and have cut several acres and have 40 more to do as soon as I quit deer hunting and take the time. I have no complaints with the King Cutter. I saw several other cheaper brands I gave no time to at all that had thin metal and poor paint, etc.
It's a solid built heavy duty mower and I have no complaints.
rICKb.
01-04-2002 12:56:28
Building or even operating a rotary cutter is not rocket science. Apart from blade tip speed, there will be more differences in cut quality due to tractor tire size and spacing, mowing pattern, grass length,texture and moisture, and hitch and tailwheel adjustments than the brand of machine. Check parts pricing and availability for any machine you consider. The definition of 'Standard Duty Cutter' will vary from person to person. Specify a make and model to recieve specific comments.
Cris
01-04-2002 05:04:17
WOODS!!!!! !
